1984 Catalina 27, Universal M18 dieselI had to replace the exhaust this spring. When I removed the exhaust flange, some liquid came out. If it were pink, I would just assume it was the antifreeze I put in last fall through the seawater intake. But as it pooled in the bilge, I saw that it's green, more like what goes in the engine side of the system. Please tell me that this stuff loses the pink color over time. Otherwise, I suspect I'm looking at a cracked exchanger or worse, cracked block. One last possibility is that the extra ports I referred to in an earlier post are actually supposed to be sealed by the exhaust flange. Perhaps in another application a flange with hose connections to circulate coolant through a fan-cooled radiator is used. It puzzles me, particularly since the original Universal manuals I have show a radiator and fan.
