Cold temperature warning signal
13
Hunter 376 St. Croix
While motoring recently, I got a cold temperature warning signal (a constant whistle).
Any idea what I should do about this? Is it serious?
Jun 6, 2006
6,990
I don't think I've ever heard of a cold temp warning on any engine. Even if you take the thermostate compleatly out the engine still warms up to over 100 deg F.
How do you know it was a cold temp warining?
Jun 6, 2006
6,990
Is this part of your speed sensor?
some speed sensors also have a SEA water temp sensor. You can set it to alarm for both cold and hot water.
Your speed sensor manual can tell you how to turn the alarm off.
Ed H
Sep 15, 2010
244
Hunter 33_77-83 Regent Point Marina, Virginia
Re: Is this part of your speed sensor?
My wife serves as my cold temperature warning device- She won't go to the boat with me until it warms up outside.
Feb 10, 2004
4,232
Hunter 40.5 Warwick, RI
Edward,
Just to be clear, what panel or instrument was this cold water alarm coming from? And were there any other anomalies at the same time? What was the make and model of the device that was producing the alarm?
