The later model O'Day 222s came through with a table and two separate mounts. One mount is bolted to the galley cabinet in the cabin and the other mount came bolted to the Port side of the cockpit well. The table can swing on this mount or be locked in position. The only drawback to this table is that you have be careful with the drinks on it. If you accidentally bang it, the drinks will surely spill. At any rate, I'm able to move the table from the cabin to the cockpit and use it while I'm sailing under autopilot.We have a 68 Outlaw. Trying to design a cockpit table that will fit in hatchway slots, easy to do support legs. obviously we have a tiller any ideas. Sources?
Thanks Jeff & Diane
That table looks a lot like the one I had in my old VW Vanagon. If is available at Go Westy. http://gowesty.com/ec_view_details.php?id=2478&search_phrase=table&start=The later model O'Day 222s came through with a table and two separate mounts. One mount is bolted to the galley cabinet in the cabin and the other mount came bolted to the Port side of the cockpit well. The table can swing on this mount or be locked in position. The only drawback to this table is that you have be careful with the drinks on it. If you accidentally bang it, the drinks will surely spill. At any rate, I'm able to move the table from the cabin to the cockpit and use it while I'm sailing under autopilot.
hi Rick.. Jeff Hubbard over on Faulkner I moor her off Tuttes PT. She was owned by Pat Testa who did moor her in the river not sure if he had her for sale then. We bought her last year , cleaned her up and have had a blast so far. Where do you keep yours?Don't know if you are partial to wood for a table, but after spending a week on the boat last summer, my wife and I decided eating off a table in the cockpit would be a lot better than holding a dish in our laps. We tried to come up with a design we could build that would be light and fold up to be stored. A tall order. One day I was wandering around Wally World and saw a folding table that I think is going to work just fine. It has a plastic table top and enamel, or maybe powder coated steel legs. It is 32" long and 16" wide. The legs snap into the top, and depending on the slot they are snapped into, you can adjust the hight. It will fit parallel or perpendicular to the benches. For $19 including tax, we got two of them. By the way, we have an Ida Sailor flip up rudder, so we can get the tiller out of the way by positioning it straight up and tying to the rear rail. It looks like you don't have that option on the Outlaw. By the way, is that the Outlaw that was for sale that was on a Town mooring ball in the East River? Rick
Rick great pictures, I drive by her every night on my way home. Ill keep an eye out for rOnDAYvous. Sounds funJeff, keep an eye on this thread for details on the great '09 O'day Owners rOnDAYvous. Cap'n Pete and Cap'n Mike seem to be in their long winter snooze, but come January or February this thread will be all abuzz about the '09 rOnDAYvous and where it will be held. The weekend is expected to be the 10th,11th and 12th of July unless something unforeseen changes the date.
Below are pictures of Apple O'Day out on Her normal mooring, and then in front of our cottage on Her "high tide" mooring.
Jeff,Thasnk Joe, I have a vsion if I can pull it off Ill send you a picture
Hi Frank,Trinky, do you have a locking bolt on your bracket? The one that I had in my Westy had a bolt with knob that locked it down pretty well. It also had a ridge around the periphery that kept things from sliding off. The design is actually a pretty good one in that it allows you to move your legs underneath easily. A four legged table makes is difficult to slide under. The criss-cross legs on mine make it a little easier. Routing a cup holder might help save you coffee to last drop. Considered a single post table. They make the post receivers flush to the floor so there is no tripping over it. Parts are available at most RV stores.
