cockpit table support hole
C
Chris Haake
Many of the Hunters have the open hole in the cockpit floor to support the table when in place. The 2X2 inch square is always full of water and crudd. I don't want to permantently seal the hole. There is no cap available through Hunter Marine. Anyone have a clever solution to cover it?
Rick Webb
Trailer Hitch Cover
found one at WalMart that was not too big, if only I could find a white one
C
Chris Haake
it works
Rick, I found a small hitch cover at Walmart that fits exactly over the square ($3). I sprayed it white with Rust-oleum primer and 2 top coats of paint. It covers perfect. Thanks, Chris
H
Harvey Small
Filled mine with plaster
I filled my receiver hitch cover with plaster so stagnant water doesn't collect and there's less habitat for insects & spiders.
Aug 11, 2006
1,446
Hunter H260 Traverse City
I use the table support (without the table). I also attached a PCV pipe T attachment and put the tiller handle into it (got the idea from someone else). It works very well and is a good way to keep the rudder straight when docked.
