cockpit table hole
  • Thread starter Nelson Brinckerhoff
  • Start date
N
Nelson Brinckerhoff
I noticed I had some leakage from the ceiling over the aft berth under the cockpit. I took off ceiling plate underneath the cockpit table hole. Water (or ice) which is caught in cockpit table hole has eventually over the years softened up base of this hole and it leaks a bit. Rain naturally pools there. I am going to screw a vinyl cap over bole to prevent this. Alternately a nicely designed square cap covering the hole with a deeper plug for the square hole would even be better. Anyone else had this issue or better solution?
Mark
Trivia Tidbit
The cockpit table hole is the same size a a trailer hitch receiver. You can use a trailer hitch cover for the hole. Note however that this is not watertight. Markdb
