Cockpit Locker Modification
Ron Williams
While on deck lockers are adequate on the 295, I'd like to enlarge the starboard cockpit locker. The aft berth below the cockpit is long enough to accomodate most NBA players but I am only 6'1". I'd like to cut as large an opening as practicle in the sole of the cockpit locker opening it to the berth below and partioning this space to create a huge storage locker. This would be a similar configuation as many other boats in the 30' range. My concern is that I could create a structural weakness. Has anyone attempted this or have any sage advice?
okiman
Oct 1, 2005
77
Hunter Cherubini 33_77-83 Okinawa, Japan
Go For It
I believe you would be strengthening the area you are considering making into an expanded locker. You would in principal be adding an additonal bulkhead in this area. You would want to make sure you glass it all in nicely and ensure you use enough glass to make it good and strong. Good luck.....
Take 5
Jan 25, 2006
14
Hunter 26 Ras Al Khaimah - United Arab Emirates
Take Photos
Hi Ron, That sounds a neat idea. Have you started the project yet? Please snap some digital photos and share the process with us. I've just bought a Legend 26, also with a shallow locker.
Oct 14, 2005
2,191
GOBM
Ron, check out the current issue of Good Old Boat Magazine. There's an article in it about doing something very similar to what you want to do. S/V Intrepid H34 #113
A
Andy
Just one hazard
If you take a large wave over the stern (or through in your case) and the locker gets push/swooshed/or blown open, you now out lottawatta in you stern...she bogs down further..swoosh, wave #2..she bogs more...uhoh...you'r sinking. SO, make sure you seal it to the hull and deck
A
Andy
Thinking more about it
Now that I think about your idea more, I wonder if you could mount the AC in the space below the locker? Sure would be a better use than what it is now huh? Cool air directly into the aft stateroom and the head? Hmmmmm
Take 5
Jan 25, 2006
14
A/C or Wind Scoop
On the same theme, could a wind scoop device be designed to vent fresh air down below via that aft locker? Food for thought indeed.
