Cockpit Fresh Water Shower
Apr 15, 2015
61
Oday 26 Gloucester
I would like to install a fresh water shower in the cockpit of my Oday 26. I want to utilize the 20 gallon Fresh Water tank that is on the boat. I don't mind if the sinks don't work as we do not drink the water anyway.
If I install a water pump inside the lazerette, connect the water to onboard tank and install a shower/hose in the cockpit. I will hook the pump to 12 volt house system (solar).
Does this sound like it is pretty doable? thoughts?
Also it would drain right out the transom drain.
Just wondering if I'm thinking everything through....
Beneteau 323 Annapolis MD
Why not install the pump on the hose coming out of the tank, and have pressure water everywhere?
