Did they stop draining?
Mike:You galley drain is under water, did it stop draining?The cockpit drains are under water, did they stop draining?If you are worried about the raw water cooling, that is what the alarm system is there for. If you turn off the raw water inlet, you can hear the difference between straight exhaust and raw water exhaust.We have had this configuration on our H'31 for 16 years, and it has served us well.
