E
Ed Hebert
It seems that my Oday 22 has a tough time completely draining the water from the cockpit. The boat seems to be pitched a little too far forward, and water tends to collect toward the forward end of the cockpit. If you dump a bucket on the cockpit seats, water tends to flow forward rather than aft, and will even drain into the companionway. Same problem down below. I just finished washing the floor down, and was forced to squeegee the water toward the bilge hole from up front. To eliminate the obvious, I don't have an excessive amount of weight forward in the boat - nothing heavy up there (at least nothing that I know about!). I completely pumped the bilge, as I thought this might be throwing the boat's weight askew.Does anyone else have this problem?
