cockit slider leak
Jul 26, 2017
109
Hunter 2000 Hunter 460 North Beach
Hunter 460 cockpit slider leaks when it rains. We believe it has something to do with the embedded solar panel. An ideas or suggestions?
BobH57
Oct 23, 2019
91
Hunter 410 Solomons, MD
I have the same problem with my Hunter 410, and have been tempted to seal around the edges of the built-in solar panel. Looking forward to others' experiences with this.
Likes: BugOutBoat
capta
Jun 4, 2009
4,958
What pray tell is a "cockpit slider"? I suppose pictures would help.
My H26 companionway used to leak very badly. I tried adding camber to the beams, calk etc. I eventually got one of these from the SBO store and it is now dry as a bone.
One tip! Put a tennis ball under the cover in the center of the slider. It will let the water run off and you won't get dried up crud buildup on your cover.
