I’m on my fifth tank of CNG and after I switched out and opened the valve there was a huge flush of CNG leaking out of the regulator. Because I’ve never had so much as a small leak before I wonder if this tank could be over pressurized to a point that the regulator can not handle it. The pressure gauge on the regulator goes to 3,000psi but new tanks tend to start out at around 1,800. I’m unable to gauge the pressure on this new tank because of the massive amount of leaking.
I disassembled each fitting on the regulator that I could and retaped with yellow gas tape and the problem persists.
I sourced the last four tanks from the same vendor where one of them had a rotten valve handle so my confidence in the vendor is low.
Anybody have any experience with anything like this?
