100cu ft , really ?
Also, the ABYC directive cited here does not apply to pleasure sailors. Do the math. >100cu ft. is huge ! The CNG tank on my Catalina is a 10 liter tank, identical size to a scuba tank. 10 liters = 0.01 Cu m = 0.35 Cu ft. , therefore far , far below the directive's measure.
My tank lasts me about 1 season ( which is short up here).
BTW, my surveyor tried to talk me into a vented locker and a switched safety valve years ago - just like for a propane set up. But the boat industry called CNG safe gas for a reason back then. All of those things don't need to be done. Except, the tank needs to be pressure tested ( just like scuba tanks) in , I believe, 5 year intervals. Too bad it didn't hold up - propane has a much better infrastructure in the US. But other than that......
Sorry for getting in late on this conversation, but I am in the middle of thinking whether to convert my CNG system on my 1986 C34 into propane or to build the CNG adapter. Here on Lake Michigan absolutely nobody fills those tanks anymore - Larsen Marine in Chicago has build a nice monopoly with an exchange program - hand your empty tank in and get a filled one back. For ONLY $120 !!! So, CNG adapter it is.Fortunately the actuarial odds usually are in our favor (until there not).Discussions with insurance underwriters (regarding recent surveys) indicated that they do not
"grandfather" systems like CNG or LPG. There is no pleasure in delivering negative survey findings.
Dedicated locker is required when tank capacity is >100cu ft. There are separate standards for devices using cylinders <16oz.
22.7.4.7 For CNG installations that include an attached combined capacity of greater than 100 cubic feet (2.8 cubic meters), the cylinders, and connected valves, regulating equipment, and safety devices shall be located on the exterior of the boat where escaping gases can flow directly into the atmosphere outside the boat, or
22.7.4.7.1 the cylinders and connected devices shall be installed in a dedicated locker.
22.7.4.7.1.1 Dedicated lockers shall be vapor tight to the hull interior, and
22.7.4.7.1.1.1 vented to the open atmosphere outside the boat, and
22.7.4.7.1.1.2 constructed of or lined with corrosion resistant materials, and
22.7.4.7.1.1.3 equipped with a means to discharge incidental accumulated water.
22.7.4.7.1.2 Dedicated lockers shall be equipped with a cover that
22.7.4.7.1.2.1 opens directly to the atmosphere, and
22.7.4.7.1.2.2 latches tightly, and
22.7.4.7.1.2.3 is capable of being quickly and conveniently opened without tools, and for operating the cylinder valves, testing the system for leakage, and viewing the pressure gauge.
I provide my survey clients with the text of the ABYC standard relevant to the survey discovered deficiency.
FYI ABYC membership starts now at $255.00 per year.
