We keep our CNG in scuba tanks and we need to refill but the nozzle at the refilling station doesn't fit. Need suggestions for an adaptor.
The original question claims that the CNG is stored in "scuba tanks." Hopefully that's not the case. Though they resemble scuba tanks, the tanks approved for CNG are much thicker and heavier in order to withstand the pressures involved.The thought of somebody building a home made adaptor for 3000+ PSI gas fills me with terror. Each component needs to be properly specified.
If any part of that lets go flesh will be shredded.
Think carefully about it.
Stu, you and Steve are aware of the dangers involved and you know what you are doing but we do not need a horde of home fabricators perhaps using cheap components and thinking they are dealing with something similar to Propane to descend on the CNG filling station endangering their lives and those of others. The number of existing CNG rated portable tanks is quickly dwindling by attrition as the manufacture of new ones may be coming to an end as manufacturers respond to the market. What then, you think they may start using scuba tanks that may no longer be suitable to hold compressed air?John, many folks have made them. Steve Dion, on this board, has one.
It's mechanical parts. Terror doesn't enter into it.
One could say the same about the ones made by Joe the Plumber in the factory on a late Friday afternoon or a Monday morning after the Super Bowl in Seattle.
I have CNG on our boat, and don't lose any sleep over it. I make sure the connections are made properly and tightened properly, too.
Your boat, your choice.
'later,CNG tanks resembling scuba tanks. Have been hydraulically tested. Where can I order the parts listed in the diagram? I have 15mm opening in my tank valve.
...in other words, you are failing every vessel you are inspecting, thereby causing the owners expenses of maybe up to several thousand dollars each? Of course you realize, by calling that out you effectively make the vessel not insurable, right? And, who wouldn't go ahead and convert to LPG faced with a major relocation and rebuild, thereby adding hazard? I know, it isn't your problem, you're just applying the standards, etc.Regarding CNG systems in boats. As I marine surveyor I have yet to encounter a CNG
system installation (in any boat that I have surveyed) that was rigged in accordance to ABYC standard "A-22 Marine CNG Systems" (i.e. tank secured in place; no non ignition protected devices or internal combustion engine in space containing a tank or contiguous
to such space; tank installed in a vented locker etc. etc.); which means that each of those systems present a fire / explosion hazard.
Suggest; before filling the tank / jury rigging a tank fitting; that you determine that your system conforms to all relevant ABYC standards.
Not failing the vessel just accurately describing its condition (based on accepted standards & practices) at time of survey. Just think what it would be like if one failed to note a deficient situation (not to mention a fire / explosion hazard) and a property damage / injury / loss of life event was caused by a "not important" defect. (Suggest you posit your position to your boat insurance underwriter for their thoughts.)...in other words, you are failing every vessel you are inspecting, thereby causing the owners expenses of maybe up to several thousand dollars each? Of course you realize, by calling that out you effectively make the vessel not insurable, right? And, who wouldn't go ahead and convert to LPG faced with a major relocation and rebuild, thereby adding hazard? I know, it isn't your problem, you're just applying the standards, etc.![]()
Thanks for that.To give an idea as to the complexity of a marine survey ABYC standard A-22 as a pdf is attached.
Fortunately the actuarial odds usually are in our favor (until there not).Discussions with insurance underwriters (regarding recent surveys) indicated that they do notThanks for that.
It starts off by stating:
ABYC recommends compliance with this standard for all systems manufactured or installed after July 2013.
Could you comment on systems installed before that date? I know from building codes that grandfathering is reasonable, and that making older buildings comply with new codes & standards isn't normally done.
Is the same true for boats?
I also recognize that "doing it right and safely" is also important.
I'm in the process of reading it now, thanks again.
For example:
EXCEPTIONS:
1. Accommodation spaces.
2. Open compartments having at least 15 in2 (97 cm2) of open...
We have two cylinders, one's in use, the other is a backup. Both fit under this exception based on where they are located and the spaces' ventilation (open ports and dorade vents).
Dedicated sealed lockers are also not required for small CNG single tanks the way I read it.
The thing I'm getting to, in parallel with Rick, is that if a surveyor reads and ticks off these "deficiencies" they simply MAY NOT APPLY to the boat being surveyed.
If a surveyor did that to me, I'd be hopping mad, 'cuz it means he didn't read the regs as they apply to MY boat.
Comments?
