C
Claude Labrecque
We have a 1991 legend 35.5 with a CNG stove. We are very satisfied with the system. A local supplier in Montreal will fill 3 tanks to 2500 psi for around 10$ CAN, a real bargain!Our problem started this summer. When lighting any of the 2 top burner or the oven, the flow of gaz is no longer smooth and producing a continuous flame. The flame is pulsating from low to high once every second. We can still use the system but it seems to take longer to boil water as it is cycling between high-low-high-low etc. Some time the pulsation is so intense that it will extinguish the flame. We have a pressure gauge on our system and this happend anywhere between 2500 psi ( tank full) to 200 psi (nearly emty). We changed the tank to a another one with same results. Any adjustements or else I should check? There is no leak in the system anywhere. Any advice would be welcome.
