Cloudy compass
Doug Washburn
I have noticed my pedestal compass has become so cloudy as to be difficult to use. Is there any cure for this condition?
K
Ken Sturgill
Change your oil
You'll need to find a shop that will do the repair, but if it looks around $100 replace it.
Dec 2, 1999
15,184
Rebuild or replace.
Doug: You can either rebuild the compass or replace it. Check with the mfg and see if they have a rebuilding program. Depending on the type of compass, it may be just a cheap to purchase a new one on sale.
r perkowski
mine too
funny that you should post that. i was in west marine yesterday looking for a replacement for mine with the same problem. my compass is a saturn from a 1984 31'. i couldn't find a direct replacement and the staff recommended i use a local ( san diego)compass repair service. they can replace the oil for less than a new one. i suggest you do the same
Dec 2, 1999
15,184
They can replace the oil.
I think that any compass shop can replace the oil but can the replace the clear plastic? I got one for my H'31 at West Marine. I think it was just over $100. Maybe something like the Ritchie Helmsman HF-79 $110. I just do not remember which one I purchased.
John
Cheap and easy fix for lens
If it is the lens, the cause is oxidation. Get Meguiars Vinyl Cleaner (#17). It has a fine rouge in it that will polish away the oxidation and make it look like a million bucks. And you don't even have to take the compass out. Seen it work many times. Same stuff that works incredibly well on our old '85 H34 windows that we originally thought we would have to replace. It works on dodger glass for scratches and the ports. Follow up with the polish as described below. One bottle will last many years. Here is the info from Meguiar's web site: Mirror Glaze Clear Plastic Cleaner Safely removes hairline scratches, dirt and grime. Clear plastic that has lost its clarity due to significant contamination and fine scratches should be treated using our two-step process. Meguiar’s non-abrasive, alcohol-free Plastic Cleaner aggressively cleans and removes scratches without harming the surface. Follow up with our M-1008 Plastic Polish for a perfect finish. M-1708 ....................8 oz. $6.25 add to cart You can obtain the product at West Marine.
