More on interior decorating an H34
The cushion vendor is:U.S. Yacht Cushions4055 35th St. N. 6000St. Petersburg, FL 33714(727)528-9644Cushions including fabric, foam: $1290 in 2000The foam backing for the naugahyde walls is a closed cell foam I found at Menards (a local home store). It is intended for backing carpeting in wet/damp locations. It is about 1/2" thick.For glue I used a waterproof carpet adhesive also from the home store. Sorry, I can't recall the brand.Folded the vinyl over the foam edges and glued assembly to the walls. Used just the vinyl without the foam in the main salon and vanity areas.Vinyl is Naugasoft; Sailrite #51006 @ $14/yd...bought too much, can't find receipt or I'd tell you how much to buy...sorry.
