How are all of you getting angle off wind?
Curious how anyone here is measuring/calculating the close haul angle? I typically just look up at my windex and see that the indicator (opposit the arrow head) is aligned with one of the edges of the windex. So I assumed this was 30 degrees to the wind, as the windex spread appears to sweap about 50 to 60 degrees of angle, its obviously less than 90, and I take the boat up to the 30 degree limit pinched and slow, but it does do it.So how would I use my GPS to measure wind angle, I assume we are talking true wind angle here, not apparent wind angle as I typically measure with my windex. I guess I would need to get a really accurate measure of wind direction when not moving, then sail as straight a course as I could and plot it on the GPS, right? Then measure plotted GPS course against measured wind angle? I would think there are too many opportunities for error on my part here.- UnderDog'86 25.5 fin keel, sails not great, just normal
