John
Need emergency assistance from knowledgeable Hunter ownwers.Set up of head lines: I am third owner of a 1991 35.5 Legend. Originally, this boat's waste line is supposed to come with a vented loop. Well, it seems the previous owner installed a macerator, and likely changed discharge lines, because there is no vented loop anywhere to be found. The discharge line runs pretty flat coming out of the toilet, underneath the aft cabin and rises about 6 inches at the end, in order to reach the top of the holding tank.Late last year I began to experience water backing up into the toilet. The Jabsco manual pump seems to do its job taking all waste out rather well. However, after pumping several times, I can hear the toilet regurgitating, and little by little, water begins to accumulate back into the bowl. I changed the joker valve, but the problem persists. I contacted Jabsco and Hunter. The believe it's not the joker valve (too new, they say, to go bad so soon). Because of the noise it makes after pumping, they believe I have a clogged discharge line, and since there is no vented loop, I can't get rid of the air pressure, which forces liquid back into the bowl.There doesn't seem to be a marine-type DRANO to unclog discharge lines (no one knows about any). I thought of two alternatives and I need your feedback:1) Pump out well; disconnect the discharge line; and put a snake through it.2) Pump out well; disconnect the discharge line: and put high air pressure through it.Will an y of these work? Should I be concerned with any of these two, like the snake getting stuck inside the hose at the end? Any other ideas? Thanks
