Climbing the mast
Aug 5, 2026
1
Hunter 240 Perry Yacht Club
I have some work to do on the mast that requires me to climb it. Its about the end of the season in my area. The question that I have, do you recommend climbing the mast when the boats in the water or on the trailer. While I do have the option to lower the mast in my marina, the work that needs done doesn't warrant putting that much effort into it. I just want to install a Windex and check on the condition of everything topside.
Thanks for any bits of knowledge.
Jun 10, 2024
339
Hunter 240 Okanagan Lake
It would take me 20 minutes to drop the mast and put it back up. I am assuming by your signature you are going to climb the Hunter 240 mast? Nope, I couldn’t do it. :)
Climbing a mast is risky. Climbing a mast on a small lightly ballasted boat is very risky. Climbing a mast on a small boat sitting on a trailer, is riskier yet.
Take the mast down to work on it. When up, the mast will act as a lever, the force generated by the lever will easily over whelm the righting force of the keel.
PEBI
Sep 30, 2026
21
Homebuilt 35 muck
There is no righting force on a keel while in a cradle on land. I only say this because if
nverbenec
thinks there is even a little righting force he might just try it because he's feeling lazy.
