My H28.5 is in a new marina and the aft tie-up posts are beyond the length of the boat. In the old marina the post was located about midship.- and the line running to the aft cleat didn't chafe the toerail.
The new marina post location creates a bit of a problem- because the line has only about a 3~4 inch "arc" area to head for the post - between the aft end edge of the toerail and the eye loop anchoring the backstay.
There is some tide, 1 to 3 feet, so I have to have enough slack in the lines and it causes some chafe. But I'd hate to have the line chafed/cut by the toerail-end abrasion or break,crack or bend the the backstay loop.
Cris-crossing aft lines never seemed to workon this boat because the stern cage rails were always in the way. In this case posts are not beneficially angled for the cage and cleats.
Question: What have others done in dealing with this situation? I'd hate to move the cleat and re-mount it inboard and higher on the "molded in" coming "pad" . BTW In the original H28.5 brochure there was a jenny/jib turning pulley mounted on that pad. Turning the boat 180 in the slip is not a benficial option either.
Have other modified the toerail in this situation? What have you used to trim back the upright portion of the toe-rail a couple inches to open up the "arc" area. Might this trimming reduce the stiffness of the deck/hull mating in that critical area. I've seen a neighboring H28(see picture) with his "upright" toerail portion eliminated the last 12~15 inches allowing for better line play. I don't know if this was an original Hunter design or his modification.
I've attach a couple pictures to illustrate the area and the other boat (H28or H29)with the rail trimmed away from the aft cleat.
