Clearance required for bimini on C30
Robert Moretti
I want to get a bimini for my C30, but I'm concerned about the clearance under the boom. When the main is furled on the boom, there is about 5'10" from the cockpit floor to the bottom of the boom. When the main is raised, the clearance is about 6' or so. Have any of you measured the clearance on your c30? If you purchased a bimini, how much clearance did you allow for? Thanks! Robert r-moretti@northwestern.edu
F
Frank Gazzano
Headroom
The biggest problem is when your sailing and have the vang on hard. If your buying the bimini from a canvas shop they should come out and take the necessary measurements before bending the stainless. Question them heavily about the location of the stainless because it can really obstruct your ingress to the cockpit and egress to the weather deck. Also make sure you'll be able to see the windex on the masthead, if not have a small window installed for that as well. If your going to do it spend the extra money and get a clear connecting panel installed between the bimini and dodger. All in all you'll probably find it's one of the best additions to the boat because it can extend your sailing season, protect you from a blistering summer sun, and make your cockpit more enjoyable for dockside relaxing.
A
A. J. Byllott
Bimini clearance on a Cat30
Consider the placement of the frames and stays with respect to the sheet winches. You will need plenty of room to swing the handles. Remember that your arms and shoulders operate well beyond the end of the winch handle. Tacking ain't no fun if you keep getting tangled in the bimini stuff. From what I've seen, most binimis on sailboats are too short (fore and aft), too narrow (athwartship), and positioned too far forward. A good idea is to have the aftmost frame behind the backstay. Even though it requires a zipper or some lacing, it's worthwhile. Else when the sun is not directly overhead, the helm will not be shaded. If the frames are mounted in tracks they may slide aft and be secured to the backstay when not in use. This, of course, assumes that your backstay permits you to stand erect while at the helm. With respect to boom height, some Cat30s have the gooseneck mounted in a slide used as a downhaul to increase tension when the sailboard is at the top of the track and there are scallops visible. Sometimes I see Cat30s that appear to be sailing with up to a foot of space between the top of the sailboard and the truck. This indicates that the boom could be raised. You may wish to check this on your boat. On pleasant days, a bimini can't be too big. But when the wind kicks up, they must come down in a hurry or the sailing gets mighty uncomfortable. If I can be of any help, email me at thefantasea@cs.com. Happy sailing.
L
Larry W.
C30 Bimini
Robert; The bimini on the C30 I had attached to the aft edge of the dodger and then to the backstay. There was standing room behind the wheel but thats all and you couldn't sail with it up very well.
Rhet Tignor
some thoughts on a bimini
I just had a new bimini made. The old one came with the boat 7 years ago. Some things I thought were important this time included. I wanted to be able to take the cloth off the pipes - zippers needed to do that. The pipes stow against the backstay with bungee and thus the boat doesn't suffer in a race from the rolled up bimini and the cloth doesn't age from being in the elements. I disagree with putting in a window to see the main or wind vane. Windows age, crack
