Clear instrument cover - what do I use? And the instrument panel itself?
Aug 14, 2021
1
Hunter 41 DS Collins Bay Marina
Hi y’all, time to replace the clear cover over the instrument panel, and the wooden panel itself. What do I use, where do I get it and how do you drill/cut it at home? Thanks!!!
Clear plastic cover.
Is it cracked or just dirt and sun damaged. Some times these can be cleaned and polished. Car detailing shops sell plastic cleaners and polishes that do a nice job on the plastic lenses of headlights. I’ve used them each spring to clean up the plastic cover of my cockpit instruments.
JBP-PA
Apr 29, 2022
734
Jeanneau Tonic 23 Erie, PA
Your choice is pretty much limited to acrylic Plexiglass or polycarbonate Lexan. Both are fine. Acrylic will not yellow in the sun, but is prone to crazing and cracking as it ages. Polycarbonate will yellow eventually but is much more impact resistant. For this application, the difference is probably insignificant.
JBP-PA
Apr 29, 2022
734
You can get either most anywhere. Hardware stores or online. You can drill and cut it with normal tools however use finer teeth than you would with wood and go slower, but try to avoid melting it. Add tape or make a wood sandwich to reduce chipping. You can heat burnish the edges if you like.
