Acetone
John,The products that are use on a boat, they are all toxic! Resins, Thinners, Cleaners, Strippers, Bottom paints, and urethanes, they are all nasty.Acetone is one of the products that is great for preping a fiberglass surface for patching. Yes it is pretty potent stuff. On uncured gelcoat it will create a tacky surface for additional coats.Long term.... We still don't know the longevity of fiberglass.Jim Willis is correct in that if there is any uncured resin in the gelcoat it will soften it. Then again there are many cleaner products out there that have been tested for a year or two and we have no answers on long term effects.My suggestion, If you have a good mask and it works for you, let us know the long term effects.By the way Interlux 202 is about the most effective solvent I have used. This stuff eats about anything. I recommend the nitrite glove that I find at my nearest Sherwin Williams store. They are about as heavy as dish washing gloves but they don't disinagrate like the West Marine nitrite one time use gloves. I use them for solvent, epoxy, general fiberglass, and paint ( urethane and bottom paint) work. They are great.If you don't own a serious mask, buy one. That way you may still be sailing in years to come.r.w.landau
