Cleaning up Cetol
249
Catalina 28 Mark 1 New Bern
While doing my Teak I spilt some cetol. Dose anyone know what I can use to remove it from the Gel coat?
Pearson 365 Ketch Memphis, TN
Acetone ... but beware, it is not nice to your gelcoat.
Jan 3, 2009
821
Marine Trader 34 Where Ever I am
Acetone has been used to clean gelcoat for decades. It will not hurt the gelcoat unless allowed to set for a long time, such as a rag that is soaked in it left laying on the gelcoat. It will strip off any wax, etc. Probably a lesser solvent should be tried first, but if all else fails the acetone might work. I say might, because once the Cetol has dried it will be difficult to get off. We use exclusively Cetol on our exterior teak. I have had to carefully remove some that was spilled with a razor blade. It is always best to clean it up before it dries. Chuck
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
Whenever I am using Cetol I keep a can of paint thinner and a rag nearby to pick up drips. It is a pretty easy to use product but it does drip especially if there is any kind of wind, which there usually is. Cetol cleans up easily with a rag soaked with thinner, not so much once it has dried.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
I pretty much do the same thing CalebD does, i.e., keep a rag and thinner handy when using Cetol. In the past, I've gotten a few drops of Cetol on the non-skid next to the handrails. It is pretty much impossible to remove these spots once they have dried. Instead, I take a small artist's brush, with a point, dip it in some white enamel, and bingo, Cetol spot disappears.... Works for me.
Yup, too late now for you! :) Gotta learn to keep cleaning as you go on a boat. Warren's idea is wonderful!
