Agree with Peggie
I agree with Peggie that the Chlorine Shock Treatment is the best way to clean out your tank and lines of all the "critters" that like to set up housekeeping there. I had a 29.5 for 4 seasons, before trading up to a 340 and I used Peggie's approach mid-season to prevent the critters.Prior to taking delivery of our 29.5, I read an article, Sail I think, that talked about using Hydrogen Peroxide, H2O2, in place of chlorine. I liked the idea and used it religiously. It called for using 1oz H2O2 to every 10 gallons of water. While the 29.5 had a smaller tank, 40 gallons, I added H2O2 every time I added water. Given the fact that H2O2 and water are very similar I always added at least 4oz at every fill-up. During the 4 seasons that we had the boat we never had "foul" smelling water, it was always clear and never tasted bad.Needless to say, I am going to continue to use H2O2 with our new 340. Has anyone else ever heard of using H2O2 for this? If so what were your results?To answer the question about antifreeze taste. Putting small quantities of water (5 or 6 gallons) in the tank and flushing it through several times at each outlet has always worked for me. When I winterize the boat I always by-pass the hot water heater and drain it. Most water heaters are at least 6 gallons, this not only saves you money in antifreeze but means there is less antifreeze in the system to be flushed out in the spring. Hope this helps.
