When cleaning the wheel at the dock not moving I don't get too much water, maybe a quart, underway at ~2-3kts I get even less, maybe a pint of water.The most sobering thought I got from removing the paddle wheel for cleaning a few times is the fact that a plan must be in some order if the
hull is ever compromised ie: being holed, or having a thru hull fail![]()
I replaced the thru hull's for both transducers this spring after I found them starting to leak last year (very slow trickle, turns out it was only bedded with silicone originally!), figured since they were plastic and over 20 years old, and I had no idea how brittle they may or may not be after that long. If I had to remove the old ones to rebed them I might as well put new material in so there wouldn't be anything to worry about.
Seeing how much came in that same hole when doing 6.5-7.2 kts Saturday, if I ever hit a log underway and holed the hull, there wouldn't be very much time to react or do something before she would be on the way down... I think that getting the dinghy up on deck and having someone start inflating it would be rather high on my priority list in that situation...
