Cleaning Products for the H216 ABS Material
L
Lamar Sumerlin
Does Boat Life have specific products that would be suitable for cleaning the ABS hull/deck/cockpit material that is found on the H216?
Mar 23, 2004
119
- - Paradise, CA
Cleaning the 216
Lamar, Check the archives. I use automobile wax on the hull, non-slip Woody Wax on the top/cockpit, and Starbrite Non-Slip Deck Cleaner to clean it. I got the Woody Wax and Starbrite from West Marine. There's probably a lot of other sources and a lot of other choices. I've been pretty pleased with my products. It is really important to keep it waxed as the surface is porous and you need to fill the pores...otherwise cleaning the surface is a nightmare.
L
Lamar Sumerlin
Thanks for the cleaning info
I appreciate your response. I will have to do something this fall about cleaning the boat up.
