I cut an opening in mine about 10 years ago and cleaned it out- it really needed it. I re-sealed the opening with a piece of lexan sealed with a permatex sealant- choose one that is impervious to kerosene or diesel. I screwed it down using ss screws. It is important to drill the holes and insert the screws before sealing. Than wipe down the inside again to get any plastic bits. Mine sealed fine- I removed it a year ago to check and clean and it was well stuck down. Here is a picture of the coverYes, I had a bottle of lamp oil for the trawler lamp on board. That is a nice clean solvent similar enough to diesel that cleaned up the inside of the tank really well. I wouldn't consider anything else like gasoline or acetone. Mineral spirits would be ok as it's a high boiling temperature solvent.Allen, you said you used lantern fuel?
BTW thanks for the note on the screen in the pick up tube.
