Cleaning an Ericson's bilgey bits...
2
Ericson 28+ East Greenwich, RI
Hi all,
I just bought a 1984 Ericson 28+, and am having a devil of a time trying to get the bilge as clean as I can. I know the best advice is to powerwash the bilge to clean it, but for this particular boat it's impossible. Ericson built the boat with a laid-in fiberglass grid under the sole, which is notorious for trapping bilge water (almost all boats built with this "tri-force axial grid" always have some standing water in the bilge, which gradually leaks out or is released after sailing). Even worse, there are only a few small access holes cut into the sole, which contain shallow fiberglass pans with a few limber holes in them (which is the only access the boat has to the bilge water....there isn't any direct access to the actual bilge at all). So, there's no way to actually get into the bilge to clean/vacuum/dry it.
Given that, my question is what is the next best approach? I've got some hardcore anaerobic bacterial growth in there right now stinking up the boat, so I want to try adding some kind of cleaner (borax? starbrite? liquid tide?) to kill what's in there and clean it as best as possible (lots of sailing to swish it around), then vacuum out as much of it as i can from the access pans. Is there any particular additive/cleaner that would be best to act as a long-term bacteriostat?
Thanks for any help!
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
I would go to a pet store and get an enzime product they sell for animal waste.... Kills all sorts of bacteria. I would flood the bilge assuming there is nothing that will get damaged, let it sit for a while and then begin vacuming....
When i cleaned my bilge I flooded it in the same way with hot soapy water... mine only was dirty from engine oil and years of crap. Came out real clean!
Good Luck!
