Cleaning Aluminum
Peter Milne
I had my sails cleaned last fall, but before I reinstall them I want to clean the mast and boom. Does anyone have a view on what is the most appropriate/best cleaning agent to use? Thanks in advance, Peter Milne S/V Blue Heron
Dec 2, 1999
15,184
Depends on what you are trying to remove!
Peter: It depends on what you are trying to get off the spar. Obviously you can use soap and water as a general cleaner. If you are trying to remove grease or lubrication type stuff you may want to try something like Eagle Wheel Cleaner for Alum/Mag wheels. This stuff is strong but should not be to caustic. I would try a spot and see how it reacts before taking on the entire job. Also be sure to see how it reacts with the gel coat.
L
Lauraine
Be careful what you use...
you don't want to remove the anodizing on your mast. We just use a sprayon like 409 or Simple Green with warm water and a scrubbie to remove the usual grime without scratching the finish. Then dry and finish with a good coat of paste wax.
