G
Gary
This just started; I have a 1989 Cat30 II when you put it in reverse it kind of vibrates a little, nosier then before. Also while sailing with the transmission in neutral you will hear the transmission turning over and making kind of a thumping sound with every revaluation of the prop. If I take and put it in to gear it will stop.Any suggestions are greatly appreciated thank you.
