Chirping sound when in gear at low RPM
linz1
Jan 27, 2010
18
Islander Bahama 30 #208 Santa Cruz
I have an Islander Bahama 30 with a Volvo Penta MD7 engine. I've noticed that I hear a chirping sound after it is warmed up and I'm in gear at low RMPs, usually when returning from a sail. I don't hear it when running above 1000 RPMs and it only happens at the end of a sail when I'm returning to the slip and things are warmed up. If I put it in neutral, the chirping stops. If I'm in reverse, it stops. Any thoughts?
Oct 17, 2011
2,809
Ericson 29 Southport..
My first thought is fluid. Have you checked it? Changed it recently?
A lot of things are occurring in the gearbox. In retreat, it's more or less using different cogs than forward. And I wonder of you sail with it in forward, reverse, or neutral. If the transmission is in neutral, it could be, (and probably is), freewheeling, causing a lack of lubrication that would otherwise be contrary to having the boat under power. But the noise you describe sounds like a dry bushing.
This is only a guess of course, hard to diagnose from description..
BobT
Sep 29, 2008
239
Gulfstar 37 North East River, Chesapeake Bay
My cutless bearing 'chirps' at lower rpms, but it's generally noticeable starting out, not so much after a run. Packing gland a bit tight and warm after some run time? Might need to find a way to listen closely to different components while underway.
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Its the packing at the stuffing box.....had the exact same problem a few years back, I replaced the packing and all is good
Jul 26, 2009
291
We have a PSS shaft seal and it's made a similar sound a couple of times. Once I burp it, the chirp goes away (there is a vent line installed).
linz1
Jan 27, 2010
18
Chirping sound
Thanks for the feedback. Will check on the packing when hauled out this week.
linz1
Jan 27, 2010
18
Yes, checked the fluid in the reverse gear and it is fine. I've been watching this area in particular because I previously had a slow leak that has since been repaired.
