Check your toe rail bolts
456
Hunter 31 Seattle
While adding harken stantion blocks to tuck the furling line away noticed that some of the bolts were loose. I ended up going around checking all of them and most of them needed 1-3 full turns!:doh:
Maybe this explains the small leak in the vberth from the starboard side...
Cheers,
-Jared
Nov 6, 2006
10,256
On the 31's and 34's , Note that When tightening, the nut should be turned but not the bolt. Turning the bolt increases the chance that the sealant around it will be broken, possibly opening a leak path..
