Check List
Richard
I realize that this has been discussed at length before but I could not find the thread in the archives. So ... Does anybody have a link to a Pre-Launch Check List that I can print out and get laminated to keep in the boat? If there is also a Pre-season check list around that would be great too. I'm trying to organize all of the paper and reference material into a single binder for on-board reference. Thanks for the help Hope to launch this weeknd. (I know it's late but we have a short season and I travel too much). Richard
jimq26
Jun 5, 2004
860
Coast Guard has them.
We just had a courtesy inspection done by the local coast guard group - TOWARF - Oakville. After the very thorough inpection, they gave us approved inspection 2006 decal for installing on a portlight, a pre-launch check list, a free Fox 40 whistle, an RCMP decal of right of way arcs. I'm pretty sure they have the same programme right across the country. Hope this helps.
Nimbus
Jun 7, 2004
45
Catalina 30 Fairhope, Al. sold 06-13-09
Try the link to catalina30.com
Here is a spreadsheet that is on the Catalina 30 website. It is fairly comprehensive.Just hit cancel when it asks for a login.
The Catalina manuals include them
try any association website, and download the manuals, most assoc. websites have them.
Tony
Check Archives
This list was on this site some months ago: Electrical Turn all DC off. Turn AC Main switch on. Turn AC Battery Charger switch on. Confirm that dock breaker is on. Plumbing Pump out head holding tank. Fill water tank. Close water tank supply cocks. Close galley sink seacock. Close head sink seacock. Close engine raw water intake - aft berth, port side. Close head raw water intake - aft berth, starboard, aft. Confirm head pump out is closed - aft berth, starboard, forward. Check hose clamps on sea cocks. De-pressure fresh water system. Flush fresh water and 1 cup vinegar thru the head. Put engine key on engine raw water intake seacock. Pull out the knot meter paddle wheel. Cockpit / Sails Clean out pedestal pockets. Stow everything inside. Stow winch handle. Stow boat hook. Remove and stow chip from chart plotter. Cover the main. Cover the pedestal. Cover the winches. Cover the bimini. Cover the man-overboard pole. Cover horseshoe buoy. Remove and stow dodger windows and sides. Wrap genoa sheets, tie them off, and hang them. Bungee the genoa. Lock the roller furling drum. Secure halyards. Secure the anchor. Haul up the swim ladder. Close the propane tank valve. Loosen the clew outhaul. Loosen the jib halyard. Hang all lines. Tighten the steering wheel lock. Lock the dock box. Check the fenders. Check dock lines. Cabin Test bilge pump. Prop cushions up. Hang mildew preventers. Secure v-berth door. Secure head door. Close and lock all ports and hatches. Hang shades in all ports. Empty, open and secure the ice box. Put baking soda in the ice box.
Jun 3, 2004
730
Catalina 250 Wing Keel Eugene, OR
Small boat bliss
Yikes! When I see a list like that I am thankful for my small and simple boat. ;-)
May 5, 2006
1,140
Knutson K-35 Yawl Bellingham
No doubt.
Mine consists of: Pre-launch 1. Is there gas? 2. Are the PFD's aboard? 3. Is the rudder in the back of the truck? 4. Ziplock for the cell? 5. Something to drink aboard (preferably water)? 6. Drain plug in? Post-launch 1. Rudder on? 2. Keel down? That's pretty much it.
C
Claude Labrecque
Good check list
Richard, I have a nice checklist available. It is in PDF format. E-mail me at: clabrecque@videotron.ca I will send you a copy. Hopefully it will be usefull for you
