Tom S. - You're probably right
Tom S. - your're probably right, there should be/could be something keeping the clew closer to the boom. While I haven't been out in a huge blow with this setup, the angles are virtually identical to the factory rigging arrangement - which I have had out in a couple of big blows. The clew does rise up some, but actually, that gives me a little more twist in the main - which isn't a real bad thing in that situation.Someone else asked about the loads on those blocks - the catalog specs (granted I didn't size them based on loads) show a MWL (max working load) of somewhere just over 1000 lbs.Tim BroganApril IV C350 #68Seattle
