Cheap cleaning tricks
394
J Boat 92 78 Sandusky
Over the years I've picked up a couple of tricks to solve pesky cleaning problems. The tannin stain that appears at the waterline has always been difficult to remove. When I switched yards I noticed they were scrubbing the waterline areas when they hauled boats with a toilet bowl cleaner called "The Works". The yard bought it at the local WMart for about $1.49 a bottle. Picked some up. Wiped it on and lightly scrubbed with a bristle brush. Immediately rinsed with a hose and Voila! no more waterline stain. Be careful and use gloves and goggles. Pre wet surfaces including the waterline stripe and rinse immediately. I've even cleaned the waterline at the dock with a long handled sponge mop.
Being on the Great Lakes they are times when we have swarms of mayflies also called Canadian soldiers. These bad boys get squashed and leave a green stain on the decks. At the end of May and early June if you see what looks like smoke on the water it is a swarm of Canadian soldiers coming at you. If your boat is docked next to a light at night you will have a nasty surprise in the morning. Once, at Put-in-Bay, we had to clean out our cockpit with a shovel.Non skid deck cleaner will get them off but not until you scrub quite a bit which is time consuming and not much fun. I noticed a guy down the dock using something different. Turns out he was using Westley's Bleche White which is whitewall tire cleaner commonly found in auto parts and discount chain stores. He just sprayed this stuff on the bug stain and it dissolved almost immediately. Wipe off with the brush, rinse and you are good to go. The best part is that a pretty big spray bottle goes for a couple of bucks. Also works pretty well on bird and goose poop.
Always test products before you get crazy and wet the surrounding areas. Good luck.
628
Legnos, Starwind, Regal Mystic 30 cutter, 22 trailer sailor, bow rider NEW PORT RICHEY, FL
cheap cleaning tips
thanks for sharring your tips for easier cleaning. I have been using "the works" toilet bowl cleaner for years. I think i also used "snow bowl" but not sure if the name is correct or not-been awhile. The active ingredient is ACID in these products so caution is of the utmost concern. I once used it on the inner liner inside my od25 and was almost esfixiated, took my breath away and left me coughing for a few days. So, be careful. It also works good on stainless steel too. Never tried westley bleach wite before, might give it a try soon. Thanks for sharing. Patrick
Aug 26, 2007
284
Hunter 41DS Ventura, California
Sounds pretty effective...and caustic. I doubt the EPA would approve and could result in some punitive action.
Jan 13, 2009
394
I would think by the time you thoroughly rinsed the stuff off it would be thoroughly diluted and pretty harmless to the environment. Just about anything you clean a boat with is strong enough to have a minimal effect on the environment depending on the concentration and whether it is soluble in water.
Mar 2, 2009
49
2 33 Rockland
Also try electrical spray to polish aluminum (I used it on the railings). CRC is 1 brand. Be careful thought to get the version without oil. the oi ess 1 is designed originally to clean circuit boards and is non conductive. the version with oil will just make a mess.
Mike
Joe
Jun 1, 2004
8,349
For organic growth, such as the brown algae... mix a few capfuls of the acid based toilet bowl cleaner in a bucket with a gallon or two of water. Use a soft bristle, long handled, pot scrubber type, brush to dip and scrub. The weakened solution, if applied with the brush, disipates quickly. They clean the water line tiles around swimming pools that way all the time so you're not doing any damage, especially if you hose down the area with fresh water.
For petroleum or rubber type stains, like dock marks on your hull or shoe scuff marks.... A little Acetone dipped on a rag will take them off very easily. Then simply rinse with fresh water.
