D. Belcher
I've never seen anything posted on using a standard window air conditioning unit to cool a Hunter 34. I tried one last summer and it worked great. Used a standard GE 5,000 BTU window unit ($119.00 at Wal-Mart or K-Mart) and set in main companionway (door) set on two standard floating cushions. Used hard plastic stock to make the spacers to seal the sides of the air condioner with the sloping sides of the doorway. Used the top two sections of the the door panels to seal the top of the unit.The air conditioner slides very easily out of the way on the cusions if you have to go out of the companionway. Also, the newer air conditioners pretty much evaporate all of the water removed from the air by blowing it into the coil fins on the back of the unit...virtually no wanter drains into the cockpit.It takes about 30 min. to an hour to cool down the cabin on 90 deg. plus evenings. Sleeping is very comfortable and can get pretty cold by morning (no thermostat on the cheaper units). I use a small clamp fan on the bulkhead in the head/vanity area to help move cool air into V-berth.Tried making a cover so the unit could set on top of the front hatch (over the V-berth), but found their was too much condensation on the cover and it did not cool the inside of the boat as well as setting in the main companionway.I have a bad back, but found the small air conditioners are light enough that I can handle them. I store it in my dockside storage.Thought someone might like to know. Questions...email dhbelcher@aol.com
