Chart Plotter Recommendation for Hunter 310
JScho
Jun 14, 2017
9
Hunter 310 Catawba Island, OH
I just purchased a 2000 Hunter 310 and would like to add a chart plotter. Maybe 7" or 9". Wondering how I could mount it on the console? Does anybody have any recommendations on chart plotters and how to mount? Thinking about Raymarine e series or B&G Vulcan.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
There are a ton of mounting options.
Ours is mounted in a pod at the helm. The downside, you can't see through it. I can't see forward from directly behind the wheel.
Some mount them on brackets leaving them easily stolen. I like the flush mount or surface mount for security reasons.
Another option is a swing mount that moves it inside when not sailing. The downside to that, you can't close up your companionway while using the plotter.
Bulkhead mounts require you to come forward to read them.
On a SanJuan 28 (has a tiller) I mounted it with keyhole fasteners and long cables so I could just easily move it from outside to in without removing connectors. With that setup we had to deal with long cables hanging down.
Lots of choices. None perfect.
Ken
171
Catalina 310 Campbell River
What other instr. do you have ie autopilot,wind if you don't have any then no problem if you do and if it older raymarine stuff then you'll need a converter so they can talk NEMA 2k or upgrade all for $$$$$$. I changed out aC-70 for a Garmin 840xs with no problem talking to the EV-100 autopilot.
Tim22
Jun 16, 2014
257
Hunter 310 Ottawa
Welcome to the Hunter 310. It's a great boat and there are a few owners hanging around here.
I just finished installing a raymarine 7" a75 on the pedestal. a bit of a tight fit as the tach and auto pilot are also there. I will be at the boat over the weekend and will post some photos.
Tim
JScho
Jun 14, 2017
9
Thanks Ken Cross for the info.
Thanks LeoLambert310 and Tim22. I too will be at the boat on the weekend. I will get instrument model numbers and photos.
pfaffk
Mar 4, 2011
52
Hunter 290 Haverstraw
Last year I bought a B&G Zeus Touch 7 and I built my own bracket to mount to the Binnacle. Hear are a couple of pictures
Sep 11, 2015
149
Hunter 31 Marina del Rey
For me, it is most important to be able to rotate the chartplotter so that you can operate it either from behind the helm or when sitting in the cockpit facing backwards (tucked behind the dodger). I have a Hunter 31 (different layout) and I just put a Garmin 44dv in place of the compass. Thus, I like pfaffk's approach best.
JScho
Jun 14, 2017
9
pfaffk - I like that, wonder if I can find a bracket like that I can buy.
Tim22 - What is the bracket like?
Thanks guys for the info!!
Tim22
Jun 16, 2014
257
Hunter 310 Ottawa
I used a couple of SS able brackets that allow just enough movement to get the best viewing angle. I think the are 1 1/2" or 2" brackets.
Tim
