I just purchased a Standard Horizon CP175C Chart Plotter that I will be installing this spring... this is my first Chart Plotter and not sure where I should mount the antenna... If I install the antenna on the stern Rail, will I get enough signal? I heard that when you heeling that the antenna tends to loose the signal... anyone sail with one on your boat? Where did you mount it? Any suggestions on where to mount it... it’s a fairly small antenna (pic attached)Thanks.FobCatalina 27
