Charing Software
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
What charting software is compatible with the Lowrance Globalmap 3300c? I assume Navionics is, but is there any others? Can any of the free software, such a SeaClear, be downloaded to the SD card that this unit uses? Thanks
Gary_H
Nov 5, 2007
469
Cal 2-25 Carolina Beach NC
I'm thinking no because as a dedicated nav instrument the actual navigation software is embedded into the chips in the circuit. I believe that the SD card only holds the charts that are access by the program. Seaclear and OpenCPN are programs written to operate on a laptop running it's on operating system. I could be wrong though.
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
You might be able to save route/track info to a standard sd card (not to one with charts). If it's anything like Lowrance, the file will be in a proprietary format which will need to be converted. I use GPSBabel for that. Seems to work pretty well. I can also recommend SeaClear and OpenCPN with a strong bias for OpenCPN.
COOL
Feb 16, 2009
118
Islander 30 mkII Downtown Long Beach
Will Charing software make me a better Barbecuer.
