Solenoid Example
JoshHere's an example of the use of a solenoid on a boat. See the link.Solenoids are also used as part of "combiners," for battery charging. Go the West Marine website, look under Advisor, Electrical, and/or read right in their catalog about combiners.Solenoids are used, as the guys have said, as relays. Say that you have a long run of wire out and back, to say a switch, and it has a large load. Just stick a solenoid in the wire where the load is, and run the same wires from the switch to the solenoid. Every time you push the switch it activates the solenoid, but the current doesn't have to run all the way to the switch, it just goes through the solenoid. It reduces the voltage drop by reducing the wire length that the usable current is flowing through.Hope that helps.BTW, some of the detailed questions are even better explained in BOOKS, like Calder and Casey.A Google on solenoids will also give you more than you could possibly ever read.Good luck,Stu
