charging problem with new batterie
Problem found...main charging system breaker tripping. Gonna replace it. House bank is 630 AH.
Thanks for all your help.
Rich
Glad to hear you found it.
Do you really have 6 group 31’s fit in a 37’ boat?
The rule of thumb is to size the charger for at least 10% of your bank size; preferably 20% or more for AGM’s. That puts your 40A charger quite a bit on the low side. You may want to consider whether a larger charger would be worth the investment to preserve the life of your AGM’s.
richk
Jan 24, 2007
495
Marlow-Hunter 37 Deep Creek off the Magothy River off ChesBay
Replacement charger is on my list. It's a question of boat $$$ vs real $$$
richk
Jan 24, 2007
495
Correct. Replacement breaker being installed
Jun 1, 2009
1,854
Hunter 49 toronto
I’d like to address one issue. A common mistake people make is increasing their battery bank, and not accounting for the other side of the equation ; I.e. charging.
With an increased battery bank, you need to address your charger, and your alternator.
if you do a lot of cruising, the larger battery bank is great to keep your fridge & freezer alive longer.
But, it will mean very long charging times on your engine with the stock alternator. On my prior Hunter, I had to charge for 2 hours before I swapped out my alternator for a larger Balmar and external regulator.
