I bought a multimeter a few months ago. I pull started my Honda 9.9a and with the O.B. cables not connected to the battery, there is no voltage across the cables wile the engine is idling. With the meter set with the same way, I read 12.74 directly on the battery (in case somebody asks if the meter actually works).I checked the 15A fuse under the cover, and it's OK. The electric start works OK.Shouldn't I see 12V across the cables? What could be wrong? I've used the engine for 3 seasons. I guess I have no way of knowing if the charging has ever worked....RickM...
