Brett Phillips
In a standard 2-battery setup, with a Starter/Battery 1, ALL, and House/Battery 2 selector dial, do you normally need to select "ALL" if you want the battery charger to charge both batteries? Whatever the answer, should I assume that the same applies when the engine runs and the alternator charges the batteries?My pal claims both batteries charge no matter which is selected. Neither of us is smart enough to figure it out on our own, especially since we don't have voltmeter gauges.Thanks.
