On our 26 footer we've been able to use a battery combiner to share charging between the house bank and the starting battey from our outboard 9.9HP 10A motor and a 32W solar panel under various circumstances. You can assume that we use the panel for trickle charging while sailing or anchored, and the motor for more powerful charging that is adequate for the 109 AH house bank. This arrangement has worked fine for several years. We also have a 110v charger we use occasionally at dock.We're now considering a wind generator so we can add more amps when sailing and run the motor's alternator less at dock or when anchored. With these various charging sources we think we need a charge controller to avoid cooking batteries in the worst case.There are many out there, from Sunsei to Xantrex and more. Can anyone offer positive or negative reviews of specific units from their experience? Many thanks!
