While this is the end of the season and the manual for my new 3YM20 Yanmar said that I had to change the gear box oil after 50 hrs or at the end of the season. So I used my vacuum pump to suck out the ~300 ml of gear oil which went well. I slowly added new gear oil to the transmission. The silver colored 4" dip stick is difficult to read with new oil. There are two marks on the dip stick, one about a 1/4" above the bottom and a second about a 1/2" from the top. The top mark is actually a hole drilled through the hollow tubular dip stick. After I poured oil into the transmission I waited 10 minutes and took a reading. I found that the new oil level was about a 1/2 over the lower mark on the dip stick, so I used my vacuum oil extractor to remove a little oil until the oil level was just above the lower mark on the transmission. I think that this is where the oil level was prior to my changing it.
My questions are? - How important is it to maintain the level of gear oil in your transmission? My manual doesn't say where the oil level should be on the transmission dip stick - where should it be? What kind of bad things can happen if you over fill it?
Gary
Gary
