My H31 has a relatively new Yanmar 3YM20. I have separate throttle and gear controls on the two sides of the pedestal in front of the wheel. In the limited time I have owned the boat, I have had to remind myself several times that reverse cannot be accomplished by moving the throttle back any further than idle. This is clearly a holdover from my powerboating days.
How difficult would it be to change over to a single control? I am speaking of a control where forward gear is everything forward of vertical, neutral is vertical, and reverse is everything aft of vertical. Throttle settings increasing with distance from vertical. In my engine operation manual, this is actually the setup pictured, so the PO obviously decided to remain with the setup from the original engine when she replaced it.
