Changing Aqua Signal interior lights in a 1997 Hunter 340
Oct 11, 2022
5
Hunter 340 Barcombs Marina NY
How do you change these lights ?
The cover comes off ... Am I supposed to twist left or right ? seems there's some kind of spring mechanism pulling the core back to the ceiling.
I don't want to break anything. I ordered a replacement one from the shop (LED) with the little toggle arm.
Like this:
Mr. Bean.
2
Hunter 340 Midland
I want to replace the same lights as you. Were you able to remove them?
Can you tell me more about the replacement light? I cannot find it on line.
WELCOME TO SBO @Erich001
This post is a couple of years old. There may not be a response.
Check out the shop here SailboatOwners.com store
Enter the search words "Cabin Lights."
JRacer
Aug 9, 2011
1,379
I replaced all of mine with LED fixtures from Marinebeam. Very happy with them.
Sep 10, 2025
2
Hunter 340 Midland
Thanks.
Were you able to just pry them out of the ceiling, or was there some trick to it?
JRacer
Aug 9, 2011
1,379
They have a spring clip that is up above the liner that holds them tight to the liner. See the pics. My replacement units are the Red/White switchable, see the pic. They come on red when switched on then you flip the toggle switch off then on to change to white.
  • Helpful
