Out haul, et al...
Frank, to answer your question about putting the outhaul at the aft end of the boom... It will be difficult to reach under sail. You don't want to be hanging out over the side wrestling the thing or trying to tackle the boom with a luffing sail. My old MAC 26 had it setup that way and it was difficult to deal with at times.As far as running it back to the cockpit, I don't change the outhaul that often to make it too inconvenient to go to the mast base to adjust it. I'll relax it a bit in light air, and tighten it in heavier air.I do try to remember to loosen it after sailing to take the stress off -- and then to tighten back up, before sailing next time. Its the first thing I check when my mainsail is out of shape -- whoops, forgot to tighten the outhaul!I added a rigid vang and did run that control to the cockpit. I converted what was the in boom topping lift control line to my outhaul line, and what was the outhaul line hardware was then employed to run a 2nd reef line. Works fantastic. The only addition was an eye strap to terminate the 2nd reef line on the boom (and, of course the reef points in the sail).Fair winds,Tom
