Our fireplace came with a wood top! This nearly started to burn on a few occasions. It looked like it came that way. It wasn't used much in the past.
I removed the top and had a SS one made with vent holes. I also added ventilation down low(in back) to keep air moving around it. It still gets very hot if used for a few hours. I intend to cut another grate on the settee side replacing the wood. This should make it even more efficient allowing more air to move from below and out.
It's alittle tricky and more work, but here on the coast of Maine, we use it quite a bit. As boat heaters go, it is fast and throws ton of heat.
http://mysite.verizon.net/vzeofej4/site ... eplace.jpg
